pulled 8,000 lb trailer this weekend
I just purchased a 30 foot travel trailer. It weighs almost 8,000 lbs empty. The cummins pulled her pretty good. With the power puck pluged in going up small inclines the egt temps pre turbo would get up to about 1,200 deg. Is their anything I can do to get them down a bit. On mostly flat road at 70mph it runs about 1,050 deg with about 14psi boost and 14psi fuel pressur. Any sugestions.
PR
PR
1200 isn't anything big. Like mentioned intake and exhaust would help. Also what was your boost on the inclines? Do you have a Boost elbow or J-hook installed on the turbo its self to help raise boost PSI?
I saw 100deg EGT reduction when towing with my 96' with a Scotty II installed. I did the 4" exhaust before gauges were installed. Can't vouch for exhaust egt reduction.
The Scotty II can get loud in the cab underload. The Tag seemed to tame the Scotty.
What tranny do you have?
If you have an auto you have an hy-9 turbo and it doesn't move much air. Especialy if you've added power.
When I only had an ez I would have a hard time pulling unless I could keep the rpms just right.
Registered
i could peg my pyro with this load if i got into it:
but i had to take her easy to keep her at 1350-1400.
1200 isnt too hot. but an exhaust and intake will cool it down like stated above
It has an auto transmision with about 5,000 miles on a rebuild (under warranty). No J hook installed either. I am gonna remove the muffler and resinator tonight.
Originally Posted by paulr161
What kind of milage do you guys get towing? I got 10 towing over the weekend. usualy gets about 14 in town and 17 on the hiway.
92smokin blacky
09-04-2011 09:41 AM
JIROBBI
07-24-2007 09:51 PM
