puck stack
Old 06-10-2007 | 09:07 PM
txsbigdaddy's Avatar
puck stack
here goes i ave a 2000 model with a power puck on it and i have a chance at geting another one real cheap wonder if they can be stacked or not.
Old 06-10-2007 | 11:18 PM
BCSCUMMINS's Avatar
If you are talking about staking two power pucks together it will not work. You can put a smarty or a TST with it.
Old 06-11-2007 | 02:46 AM
Ph4tty's Avatar
This is one of those cases where two is not better than one =P
That advice will cost one powerpuck. Please mail to,...
Old 07-06-2007 | 01:25 PM
ok is a smarty the only programer i can use or can i use a superchips/hypertech.
Old 07-07-2007 | 02:12 PM
afoulk's Avatar
Not sure if the power puck adds timing and fuel, but if it does, that combo would add to much timing...it wouldn't work
Old 07-07-2007 | 03:51 PM
Ph4tty's Avatar
You can use a tst. Fuel only
Old 07-07-2007 | 05:10 PM
Jturs's Avatar
can you stack a smarty and a superchip on a 99
Old 07-07-2007 | 07:32 PM
dodgeguy71's Avatar
I just bought the puck and I'm pretty sure it adds timing and fuel with boost fooling. I too was wondering about a stack, but think I'm gonna go with 75-100 edge nozzles first, modified wastegate.....cross my fingers that my clutch holds up....
here is a link for the puck, says what it does......http://www.thoroughbreddiesel.com/diablo/power-puck.htm
Old 07-08-2007 | 01:49 AM
so basicly i need to find somthing that just adds fuel. like a smarty on the even numbers
Old 07-08-2007 | 09:21 AM
dodgeguy71's Avatar
Yep, I believe that's what they are saying. I'm not to familiar with the other power adders but smarty would work as you said.
Old 07-08-2007 | 11:27 AM
LUKE-MM-PULLER's Avatar
The puck will not do boost fooling.
Old 07-08-2007 | 03:20 PM
CarcajouCummins's Avatar
The Smarty will be a big disappointment. The Smarty adds a little throttle response, but no power. Stack a TST or an FMS with it.
Israel Sweeney
30
07-03-2008 02:39 AM
tex23455
02-18-2008 08:57 AM
BIGDAN65
16
01-23-2008 11:02 PM
RAMnUTAH
13
05-01-2007 01:49 PM
emoryemt-i
03-10-2007 02:01 AM
