puck question
Old 08-08-2008 | 01:36 AM
cumminspower79's Avatar
puck question
I was wondering if a 1998.5 power puck will work on my 2002. I searched for a while and I couldent get a stright answer. I know the difference is the 7153 puck plugs only into the VP and the 7155 plugs into the map for the 02. The reason im asking is a friend of mine let me borrow his to try it out. Also I have a hypertech programmer on stage 3 right now, will it work in conjunction with the puck? Thanks
Old 08-08-2008 | 09:07 AM
Ph4tty's Avatar
Only thing the puck will do over the hypertech is allow you to block off your wastegate for a few more lbs of boost w/o throwing codes. They do the same things otherwise.
tex23455
02-18-2008 08:57 AM
BIGDAN65
16
01-23-2008 11:02 PM
LUKE-MM-PULLER
06-20-2007 11:25 PM
surfram
11-13-2006 12:24 AM
doodah
07-15-2004 08:26 PM
