Proud new owner...Now what?
Hey guys, I'm the proud new owner of a 1998 12valve quadcab with 200,000 miles on her. The truck came with a 4" turbo back exhaust, K&N intake (I will soon be getting rid of that sieve for an air filter), 300 bosch injectors, and a performance auto trans. The truck has decent power as I can tell it definitely does have bigger injectors. It wasn't until I drove it home on the highway that I could tell the transmission was slipping when in overdrive. So, at anyrate I'm having the tranny rebuilt by a licensed Goerend tranny installation shop here in Mass with goerend's 3-disk converter, billet input, upgraded clutches, billet flex plate, shift kit, and some other goodies (no billet output though)... This truck will be my daily driver while I commute to and from pennsylvania (700 miles round trip) once a month. If I tow anything it would be a 6000# wood chipper and maybe my Ford 1720 tractor. But no 5'er as of yet. I want to maximize the efficiency of my mighty cummins. What I have yet to install are the gauges (boost, pyro, fuel pressure) (Yea, I was in shock too when I found out the PO installed injectors without gauges). Next I'm entertaining the idea of a fuel plate. Which plate do you guys suggest? Would it be a waste of money to change these bosch 300 sticks out for say, 75hp DDP injectors, in terms of mileage? And if they are better, would I be pushing the stock turbo out of its efficiency range? Any suggestions or comments would be greatly appreciated.
1 Post
The DDP injectors should give better mileage over the 300s. And to get the most benefit ditch the stock turbo for something like a modified S300 like a 62/65/12. Also I would set the timing to about 16 degrees.
I would try a number 8 or 6 fuel plate, your truck has the 180 pump http://www.tstproducts.com/94-98dodg...thvideo-1.aspx
How about some pics of your truck, I have a '98 12v club cab short box.
IOHDRAM
02-11-2011 12:57 AM
Bersaglieri
19
07-25-2007 08:27 PM
Suburbanite
07-16-2003 07:37 PM
