Proper way to instal lock up toggle?
I got a stock 02 auto. I would like to lock up the converter when I'm towing and I know that this can be done by wiring in a toggle between ground and the orange/black wire to the lock up solenoid. Does anyone have a good diagram or insight into this so that I don't throw a code or really mess something up. I just don't have the dough to buy a controller ala BD etc.
Ok thanks for the info. I still have some question as the how the trans will act when I have the switch on (grounding that wire out?). Some have said it will shift into 4th, some have said it will up shift but not down shift...just wanted some clarification and to be sure that grounding that wire is what to do and not just looking to start a fire. Also is the switch sufficient or should I use a relay? If I install a relay hooked to the brake switch will it re lock up when I let off the brake?? Sorry for all the questions...measure twice, cut once.
Thanks
Thanks
Thanks
Thanks
You'll usually also have to pull the trans relay out of the underhood fusebox and install a jumper wire, or else they'll throw a limp mode when doing the mystery switch.
Some truck do, some don't....
Thanks for the reassurance.
If I install a relay to break the switch circuit when I hit the brake, will it unlock and downshift? Will it re lock when I let off the brake? Just curious as how to maximise the braking ability with out spending 5 g's on a tranny, converter, lock up controller, and exhaust brake.
Anyone have any specific info on this?? Mine is an 02 do I need the jumper?? Wich ppins do I jump??
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
1 Post
I left in the relay. And I didn't jump any wires. All I did was to tap the orange w/ white tracer wire, connected a wire to it and ran it into the cab to a 33 ohm resister to a toggle switch. The a wire from the other side of the switch to ground. No problems at all. Works great.
those instructions sound okay but go to www.tstproducts.com and then click installions and you should see lock up switch. should be even clearer. if you take your truck out of overdrive and into 3rd gear then lock the converter thats good for slowing down with or without a trailer. and if you going 20mph and lock your converter and your in overdrive its gonna lug the motor in 4th gear, which makes for some nice smoke but would be pretty bad towing so...have fun with it.
I'm getting ready to do mine also but I'm also wondering about hooking it up through the brake switch. I thought a member here had a diagram of his truck with this set up. Any ideas how to do it right?
I'm confused again
I installed mine yesterday and played with today,I have 33 ohm resistance between pin 11 and ground with switch on, but has no effect on lock up..does this mean I have to jumper trans relay?..no codes but no difference in lock up either..if I can get this working have to do the 03 ram next.
1 Post
Run the wire from the trans orange with black stripe to one side of the switch. On the other side of the switch solder in the resistor and connect it to a good chassis ground, all done.
