propane injection hoses??
Old 12-15-2008 | 08:00 PM
MDowns's Avatar
i just got a used powershot 2000 and i was wondering about the hoses..does anyone know if i need to use a certain type of hose to go from the powershot to the intake or can i use any type of rubber line? just wanted to do it right the first time..
Old 12-15-2008 | 09:00 PM
Gunrunner's Avatar
I use hydraulic lines---cause that is what I had, been using them for 10 years or so.
Old 01-06-2009 | 12:03 PM
Powershotone's Avatar
If you leave the system on the tank , you can use 1/4 high quality fuel line hose. Hose clamp at both ends If you move the regulator assembly off of the tank, you must use High pressure LP hose with special crimped on ends and fittings.
Flatbed24v
07-31-2009 11:57 AM
PowerDually
06-12-2005 11:51 AM
wannadiesel
05-23-2003 08:05 PM
