propane good or bad
Old 03-29-2004 | 08:40 PM
ox's Avatar
ox
propane good or bad
look here i know how to make my own but what are the egts like and what dose it hurt or is it safe i got an edge ez and thats it well i got a pyro to but thats it and straight pipe stock exhaust will i need bigger or is it ok to run it with 3 inch thanx for the info
Old 03-30-2004 | 08:53 AM
j-fox's Avatar
Actually it is the wrong kind of fuel to run in a diesel!
Propane will make the motor run as if it has advanced timing. Becareful if running a timing box with it. Read the egt if you try it.
Many have damaged the head gasket. Many have noticed better fuel mileage.
You will only need bigger exhaust if you have heat problems.
Can you afford to put a head gasket on it?
Flatbed24v
07-31-2009 11:57 AM
coonhunter723
11-03-2007 12:43 PM
Buckshotram
01-09-2006 10:27 AM
PowerDually
06-12-2005 11:51 AM
C Pierce
03-21-2005 09:41 AM
