problems installing juice w/attitude
I have installed my juice w/attitiude per the instructions,but the display doese not do anything when the key is turned on. Does anyone have any suggestions? I would like to resolve this if possible before waiting to contact Edge till after christmas.
uh, plug it in? seriously.
check the ground, as well as your hot wire. does the module have power? is the module putting out power to the monitor cable?
jeremy
jeremy
Yes it is plugged in,and the ground is direct to the battery. Instructions stated to connect wire to spare 15 amp fuse in eng compartment fuse box or quad light fuse. I do not have a spare fuse location, so it is connected to the quadlight fuse.
get a voltmeter and start verifying you have power to everything you need power at. you should do it anyways and if the monitor is bad, its not like you have the chance to replace it today anyways. be certain you have power everywhere. double check power at the fuse where you are jumpering from.
jeremy
jeremy
I got it working, the fuse tap for the #9 Fuse inside the cab popped out. They don't push back in too well with the fuse tap on , as i'm sure you all know. Thanks eveyone for the help.
they push in fine once you rework the plastic...
good to hear everythings fine. now give yourself an early christmas present and go race some imports.
jeremy
jeremy
5.0 Mustang Man
10-21-2008 02:50 PM
