Problems
Problems
K i will start by saying that i just had my LP and IP replaced under warranty...and i want too hook my comp back up (wire unpierced). The only problem i am having is....it seems that after the new IP and LP there is no more plug in for the chip. I looked all through the wires...but cant see it.
Has anyone else encountered this problem?
What else could i do?
Jon.
Jon.
Check to see if it's been squeezed ibnto a spot somwhere.
The fuel filter housing probably got pulled off.
They had a good deal of your motor dissassembled,, the plug may have gotten squeezed into somewhere it shouldn't really belong.
There is no way to "remove" it, without cutting it from the wiring harness. You should see atleast cut wires.
I suggest a more thorough search of the drivers side engine compartment.
Merrick
Merrick
