Problem please help
Problem please help
I've got a juice/attitude combo and over the past few months the screen on the monitor has gotten dimmer. today I couldn't even read ANYTHING. Is there anything I can do to fix it or is the monitor just crapping out?
thanks
thanks
I had surging issues, the tach was bouncing back and forth. At 45 mph it was at it worst. I disconnected the batteries and left it alone for about 30 minutes to make sure that there was no charge left. I hooked them back up and wrapped the ground with foil, turned the key, but didn't engaged the starter, floored the accelerator and let it out easy for the reset and haven't had a problem since. I thought it was going to be a lot bigger problem when I first noticed it but decided to make sure and eliminate the easy answer before I moved on further. Too many times I've dug into things and figured out that it was the easiest answer that was the culprit. Just a thought...
MoparRiggan
01-17-2006 12:43 PM
