pre-luber help
Old 06-06-2008 | 12:53 PM
wyomingpower's Avatar
pre-luber help
So I had a friend give me a pre-luber that he took off his pickup because he was scared that the brush would create problems with the hose that comes out of the oil pan. I need to know what needs to be done to where the filter screws on so that I can pump it through the oil filter instead of just dumping it in the system. Also how much fluid are these things supposed to process because when I used some old oil to clean out the system it was probably doing only a couple gallons a minute. any help would be great
Old 06-06-2008 | 02:02 PM
tempforce's Avatar
i'm looking for a 18 mm drain pan t-fitting so i can use a 1/2" fumoto valve and a 1/2" hose fitting.
OVERTORQUED
07-21-2015 09:16 PM
broncobilly
09-20-2011 10:52 PM
whereswaldo250
01-13-2010 11:56 PM
mhuppertz
06-26-2008 08:55 AM
sshelly
01-30-2003 07:52 AM
