Pre-Lift Pump Auxillary filter?
Old 02-09-2008 | 02:14 AM
hink's Avatar
Here's the stock oil filter with the primarys.......so you know just how big they are.
Well, that answered my 2nd question.
Old 02-09-2008 | 05:28 AM
Truckman's Avatar
Talking $4.00 at napa
I will stick with what I have,,They are $4.00 at Napa and I change them every other oil change,, I dont have as much money as the rest of you guys,,,,, BUT Those other filters are sweet,,
Thanks
Old 02-12-2008 | 02:06 AM
rattlerbob5.9's Avatar
I use the permacool filter and head assy from summit like dieselfarmboy i mounted it on the frame rail real close to the front of the tank. Another thing i like about it their is a manual drain on the filter element. Nice to have if you were suspecting a fuel related problem out on the road such as water and or gas in fuel or maybe gelling real easy to take a sample . The filters are reasonably priced i carry one on board all the time easy to change and it should keep the walbro happy for a long time.
Old 02-12-2008 | 06:51 AM
Moose10's Avatar
Thanks
Are you talking about the small galvanized looking filter that goes between the tank and the Fass or HPFP?
Got a Napa P/N?
Old 02-12-2008 | 09:54 AM
supr's Avatar
Do you guys use a shut off valve before the filter to keep from getting a diesel bath?
I guess you also bump the starter to get the air out of the lines?
Old 02-12-2008 | 10:42 AM
johnh's Avatar
here's my setup, it's a racor 2 micron before the lp.
the filter head has a primer built into it.... no on/off valve .I've had this setup for years w/ no problems
http://s219.photobucket.com/albums/cc311/johnretbm/
Old 02-12-2008 | 11:23 AM
You can add a shut off if you like but most are installed with a least a little rubber line between fittings so you just pinch the line to avoid the diesel bath.
Put some known to be very clean fuel in the new filter install and then bump the key to cycle the lift pump 1 or 2 times to purge the air. Fire it up and you are on your way
Old 02-12-2008 | 02:59 PM
Truckman's Avatar
Talking Yes
Got a Napa P/N?
BUT You have to make sure it has the metal mesh on the inside not the paper element,,They can tell in the Napa book, I will look for the number,,
Old 02-12-2008 | 03:24 PM
hink's Avatar
Yeah, cough that up!! I didn't know that NAPA had an inline filter with the mesh screen.
Old 02-12-2008 | 04:37 PM
Truckman's Avatar
Talking pretty sure
Part Number: 3270
UPC Number: 765809151734
Principal Application: Cummins and IHC - 3/8" In-Line Fuel Strainer - 120 Mesh - can be used with gas or diesel
Style: Fuel (Complete In-Line) Filter
Service: Fuel
Media: Wire Screen
Height: 3.850
Outer Diameter Top: 1.940
Outer Diameter Bottom: Closed
Nominal Micro Rating: 141
I think thats it.
Old 02-12-2008 | 05:07 PM
supr's Avatar
How much was the NAPA filter? Do they have repalcement inserts?
Old 02-13-2008 | 06:06 AM
Moose10's Avatar
Part Number: 3270
Service: Fuel
Media: Wire Screen
Height: 3.850
I think thats it.
Thanks! that sounds like the one that came with my HPFP size wise. It's been on the truck since I installed the HPFP back in '04 and I should probably change it out.
Old 02-13-2008 | 04:27 PM
Truckman's Avatar
Talking Look alike
Yes The filters look just alike,, I dont like the idea of NOT being able to see the media inside, Paper or metal screen,,,
Old 02-16-2008 | 09:03 AM
high bid's Avatar
this is what I'm running....maybe worth a try
http://sanantonio.craigslist.org/pts/572176397.html.
Old 03-03-2008 | 05:06 PM
supr's Avatar
I decided on the Summit 40 micron. I like the replaceable/cleanable screen. NAPA has a shut of valve $15, plus $5 for hose fittings. Part # 6809 and05705B. I will be using a new AirTex pump, see how it does with my Vulcan kit.
I have gone through (3) Carters in 40 k miles.
So, with the shut off valve, easy to replace whatever in the future.
