Pre-Lift Pump Auxillary filter?
I used a filter housing off of a old 7.3 idi motor I had laying around and put it under the bed with a big wix filter on it. Works great and the filters are like 8 bucks apiece. I did change the lift pump to a walbro 392 on the frame at the same time.
I have a pre-strainer "filter" before my Walbro as recommended by GDP. I want my Walbro to last as long as possible. Don't think it hurts pressures at all. But sucking thru a standard diesel filter may hurt a pump over time since it has to suck harder.
CORed
CORed
Napa Strainer
I used a Metal fuel filter with a paper cartridge in it ,on the FIRST walbro,, The suction from the walbro collapsed the paper cartridge in the fuel filter which starved the FIRST walbro,, Thats why I say use a filter with a metal mesh inside it.
Sumthin like this is what you would need. (just an example) http://store.summitracing.com/partde...5&autoview=sku Just sumthin to keep the bigger "chunks" from goin thru the fuel pump.
Mount this on the fram rail and get (2) 1/2" NPT to 3/8" barb fitting for the inlet and outlet. http://store.summitracing.com/partde...5&autoview=sku
Usually, the general idea is to mount a larger micron filter before the lift pump to keep the bigger "chunks" out of the fuel pump, as I stated before. Then you mount your finer micron filter for the IP after the fuel/lift pump. If you mount a small micron filter before the lift pump, there is a possibilty of starving the lift pump of fuel or making the pump work harder, especially if you have a habit of picking up "dirty" fuel from area suppliers.
In fact I do, he got it from me I have about 1/2 dozen of them in my garage. new heads and new filters. At work we get them shipped to us with every Detroit we buy, and turf this stock setup for a 3 element 10 mic Racor setup. But I was allowed to salvage these before they hit the dumpster.
......actually I bet you are going to need another shot for perspective
Here's the stock oil filter with the primarys.......so you know just how big they are.
