power steering
power steering
ive had 35's on with no lift since truck was brand new, now after 155,000km power steering is whineing like crazy, driving me nuts.
wondering if its the tires and if anybody else has had ths problem. if so whats the best way to deal with it?
If you have not changed your PS fluid in a while, that could be the problem. Especially on 4x4's with bigger tires. Easiest way is to get a rubber balled battery filler and suck fluid out of resevoir. I have had great luck with Amsoil's synthetic ATF. Refill reservoir and let it circulate. I do mine @ 60 days or as often as required to keep fluid from turning black.
I'm sure others will chime in on more elaborate ways to change complete system. This works for me.
RJ
RJ
Pick up a bottle of Lube-Gard PS system additive from the auto parts and give it a try. It's great stuff, had it take the squeal out of a neighbors truck that had been squealing for ten years. Also eliminates cold weather squeal.
I used to recommend switching over to synthetic on these rigs to eliminate the squeal but the Lube-Gard is so much easier.
I used a $.99 turkey baster with a 8" section of 3/8" fuel hose to siphon out a 1/2 qt at a time.
1. Siphon out everything the reservior
2. Fill with new fluid
3. Replace cap **IMPORTANT**
4. Start the truck
5. Turn steering wheel completely each way ~3 times
6. Repeat until fluid coming out becomes close the to color being added. It took 2 quarts before mine became clear.
HTH,
brandon.
4. Start the truck
HTH,
brandon.
Dean Snow
11-14-2007 04:36 PM
DodgeCowboy
08-28-2006 08:57 PM
