power puck stack
power puck stack
what can i stack with the power puck. I am going to get the walbro setup shortly and would like some more power not too much just enough to run with the neighbors dmax and still not kill my stock tranny. would i be better off with another box or buying some injectors
If you want to tap the wire then run a TST, the TST will probably call for a valve body, maybe a torque converter. If you dont want to tap the pump run a set of sticks that fit what you use the truck for. And........about trying to run with that D-Max...........If its stock, MAYBE, If he has some mods, I would doubt it. They are fast.
Good Luck
Jamie
Good Luck
Jamie
BIGDAN65
16
01-23-2008 10:02 PM
kwhite
05-19-2007 11:16 AM
goose2w1
05-08-2007 02:03 PM
rkelley
04-15-2007 07:54 PM
