View Poll Results: What are your max egts?
<1000
5.05%
1100
15.15%
1200
14.14%
1300
12.12%
1400
18.18%
1500+
38.38%
Multiple Choice Poll. Voters: 99. You may not vote on this poll
Post your max egts
Old 03-08-2006 | 03:55 PM
BCB's Avatar
BCB
most i see is 1100 wot but i am mostly stock.For now
How hot can i run at sustained (pre-turbo)
Old 03-08-2006 | 03:59 PM
gunracer1's Avatar
i have pegged a 1500 gauge so many times i can't even take a guess. when i finally popped my head gasket i was scared to see what the pistons looked like. guess what, they looked like new. and this truck sled pulls, dragraces and has had many a highway runs over 130. these things are tough.
Old 03-08-2006 | 04:03 PM
Bobcat698's Avatar
I hope I have the same luck
Old 03-08-2006 | 04:26 PM
HOHN's Avatar
I once saw 1550.
Clutch won't hold hard enough to let the engine even get dangerous. I have the fuel for danger, though
With a clutch, I'd expect to be able to hit nearly 1600 with M4s and smarty on a poor stock turbo.
h
Old 03-08-2006 | 04:59 PM
Mine will peg the 1600 degree pyro in 4th or 5th on straight #2. I see I'm not alone with this problem.
Old 03-08-2006 | 05:08 PM
RowJ's Avatar
I agree with Gunracer1!
When truck was new, I spent 18 months being uncomfortable over 1250*. Finally realized it not "how Hot".... it "How Long when Hot".
I have seen trucks that burned pistons towing in the mountains... holding 1250* for 10-15 min.
In 1/4 miles runs, with previous (smaller) turbo, I would have 5-7 sec with gauge pegged (1550*+). Had to be well above 1550* with No Neg. side effects! I firmly believe anything up to 1600-1700 degrees for no more than 8-10 sec will not hurt anything!
For my present setup... 8 sec pegged on the pyro would peg my speedo also
RJ
Old 03-08-2006 | 05:36 PM
Underpsi's Avatar
Mine will peg 1500* gauge in 4th and will hit hard in 5th. I only hold it there for a couple seconds
Old 03-08-2006 | 08:22 PM
rebal's Avatar
1300* for miles and miles thats on my tow rig but I like to keep it at 1200*. my 90 i have seen 1400+ but short 10 sec bursts
Old 03-08-2006 | 08:41 PM
JTrantham's Avatar
I could peg my 1600* guage in about 3-5 seconds of full throttle from a stand still(with stock motor and charger).
Old 03-08-2006 | 09:20 PM
Turbo6guy's Avatar
Well, seeing all you guys with these high EGT's, maybe I shouldnt be so concerned. I can easily see 1300-1400 with the comp on 5/5. What can I do to cool it down when I start adding more goodies?
Old 03-08-2006 | 10:40 PM
JD730's Avatar
The 93 has seen 1400 numerous times on the dyno, too chicken to do it while pulling a trailer.
The stock 2000 won't go above 1000 preturbo with smarty on #9.
Old 03-08-2006 | 11:10 PM
oestreich84's Avatar
1150 tonight with the comp on 3x5 and the clutch slipping
Old 03-09-2006 | 12:15 AM
cumminsdriver635's Avatar
I could peg my 1500* gauge by 70mph before I got the timing advanced. Now it goes to 1300*, and slows down a lot, and will creep up to 1400* if you stay into it long enough. In valet mode; 1100* is about as hot as I can get it even with a trailer, unless I lug it quite a bit. 1150* is the most I like to SUSTAIN while hauling. Some say 1300* all day, but I dont have the guts for that. Id rather be safe than sorry. Sure; if im messing around, i dont care to get it to 1400*(at least twice a week probably), I just dont like to sustain it.
Eric
Old 03-09-2006 | 01:15 AM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
#10 fuel plate is only 1/2 forward, gsk and lenny's stage 4 injectors make for a real clean towing setup. minimal smoke light to moderate haze, black smoke only right off the line. once thetwins catch up shes fine. HX35/12cm WG hybrid and S400 spools like a stock hx 35/14cm wg.
1200 egts donner pass with a 12k lbs trailer and my foot burried in it 45mph at the bottom and still building steam a the top when we crested at 80mph mind you if it didnt have any corners i could have probably been even more reckless but as it was at 3 am nobody was on the road but me and the CHP who clocked me at the top and wanted to know what was going through my mind.
I told him diesel fumes. he laughed said he was impressed and told me to watch it, speeding is not something he likes to let people go for but for some reason at 3 am he seemed to find it in himself to be generous. i still have the warning citation though. he poped me for a taillight instead.
Old 03-09-2006 | 02:59 AM
runamuk's Avatar
ddestruel,
Feeling lucky I hope!
Rick
Quick Reply: Post your max egts
