Posi Lock Questions
Posi Lock Questions
Got a couple of questions for those that have installed posi lock....
1. Where have you guys got the kit from?
2. Where did you drill through the firewall and mount the pull cable? Pictures would be helpful.
3. Any tricks/things to watch out for installing.
Thanks
Thanks
I bought mine directly from Posi-lock. You can get them from Summit, etc... even ebay. The **** is mounted to the bottom of the dashboard to the right of the go pedal. I ran the cable staright back and drilled through the fire wall, and ran the cable out past the inj. pump and under to the back side of the front axle. I drilled a very small hole first and stuck a fine wire through it to make sure I wasn't going to hit anything.
jmccart
07-10-2007 12:46 PM
jmccart
07-07-2007 01:46 PM
TxDiesel007
07-29-2005 03:47 PM
