Posi Lock Pictures
I believe someone is looking into the transfer case for this control. A lot of off roaders will put an another stick in the transfer case to lock the front or the rear individually the offroad brains may know a source, or check with Advance Adaptor for a start. ED
Dyna Trac has a one piece axle to replace the two piece axle and eliminate the cad all together. Just remove the two piece axle and cad system and replace with one axle shaft. Will work with factory spindles and unit bearings. Cost is about $499.00.
jmccart
07-10-2007 11:46 AM
jmccart
07-07-2007 12:46 PM
TxDiesel007
07-29-2005 02:47 PM
