Posi Lock Pictures
Old 11-08-2007 | 06:32 PM
CODODGE2500MAN's Avatar
Posi Lock Pictures
ANyone have pictures of the install?
Either the process of installation or pictures of where you put the ****?
Thanks all!
Old 11-08-2007 | 11:06 PM
displacedtexan's Avatar
Nothing helpful here, just a bump back to the first page.
Old 11-09-2007 | 01:43 PM
TxDiesel007's Avatar
IN my gallery
ull find one of a finished install... theres nothing hard about the install.... HEck ive even got a writeup somewhere too
Rick
Old 11-09-2007 | 03:48 PM
IntakeRacing's Avatar
i just ran outside to snap a pic for you, but the site here is saying pending approval so i'll post it as soon as that is off
Old 11-09-2007 | 08:51 PM
scottsjeeprolet's Avatar
Originally Posted by TxDiesel007
IN my gallery
Rick
Old 11-09-2007 | 09:22 PM
Moose10's Avatar
How does that work, and where do you get one?....homemade?
Is it just a longer collar that keeps the two shafts combined?....
I always thought the posi unit was in the diff.....confused
Old 11-09-2007 | 09:46 PM
http://www.4x4posi-lok.com/
Positive engagement of the front axle, and enables 2wd low range.
Old 11-10-2007 | 12:08 PM
it still is a collar just instead of air pushing them together (which mine was getting lazy at) its cable that pulls them together. so its instant.
Old 11-10-2007 | 01:08 PM
XLR8R's Avatar
Aren't they vacuum operated?
Old 11-10-2007 | 04:30 PM
From the factory, the Posi-Lock converts it to cable opreated.
Old 11-10-2007 | 11:42 PM
hey can you still engage them on the roll? and if so what order do you guys use? i'm scared to try it out. haha
Old 11-13-2007 | 09:34 AM
mudwisr2's Avatar
Do you put the t-case in 4wd and then pull the cable? Can you shift on the fly?
Old 11-14-2007 | 01:01 AM
mudwisr2's Avatar
btt..............
Old 11-14-2007 | 11:16 AM
Philabuster's Avatar
Think of the Posi-lock as a set of manual locking hubs you activate from the inside. If the hubs are engaged in 2wd, you can let off the power and slide it into 4x4 because the front axles are spinning the ring and pinion (and driveshaft) the same speed as the rear. I wouldn't attempt to engage 4x4 at speed when the Posi-lock is disengaged--grinding noises may follow.
Old 11-14-2007 | 12:46 PM
Ed ke6bnl's Avatar
Just found this product in GENOS garage catalog. called BD 2-Low Kit looks like it allows you to disconnect the front hubs while in 4wheel drive. looks like it still uses the vacuum system BUT disables the vacuum to front hub and you will have 4wd low without the front diff in gaged. Ed $114.00
