View Poll Results: Whats your setup and have you had a leak ?
Mechanical in cab, never had a leak.
95
61.69%
Mechanical in cab, and I had a leak.
2.60%
Electric, no leaks.
32
20.78%
Electric, I have had a leak.
0.65%
I have no fuel pressure guage.
22
14.29%
Voters: 154. You may not vote on this poll
Poll for those of you with FP guages
Just want to see who has either a mechanical or a electric FP guage. And I also want to see if anyone ever had a leak in the cab.
Only had my gauge a week or so, but not too worried about a leak. Diesel stinks, I would detect it in the cab right away. I have a Drain C*ock type valve (thanks to Bill for identifing it) Unhooked from the hose it allows about an eyedroppers worth by every few seconds. Point being that a darn near CLOSED vavle in-line should be dampening or eliminate anything harmful comming from the LP or IP. The fact that Diesel is nasty, and could weaken the gauge itself?, that I don't know about. Time will tell. If mine fails, I close off my valve, $35.00 later, new gauge installed all is well again.
Good poll idea.
Good poll idea.
Originally Posted by ratsun
If the electic leaks is it 12v that leaking
Sorry I had to
Sorry I had to
Just because it's an electrical you aren't immune to diesel in the cab.
Administrator / Scooter Bum
Many who use the isolator find that the diaphram ruptures before long and you either end up with a leak in the engine compartment, or fuel to the gauge anyway.
I have never used an isloator, just a length of stainless braided line straight from the fuel filter canister to my gauge on top of the dash.
Click on the links to "gauges" and "Fuel Pressure" in my sig for pics.
Originally Posted by Phatboy
Only leak was because Napa sold me a drain valve instead of a needle valve I found the leak as soon as I started the truck for the first time
I have the drain type valve and I have reason to believe that it will work just as well as the needle.
Originally Posted by infidel
I worked on a truck where the electrical fuel pressure sender was leaking and diesel followed the wires into the cab.
Murphy musta hated that guy
