please help, i need to finish b4 dark!
ive been looking for over an hour and cant found out how to grind my fuel plate, all i need is a picture of one that has been done, and some information on which on i need, im running a 96 5 speed and this will be the only mod.
please hurry i dont have much time to finish, i take a night class and need to be able to drive there
Make sure to smooth that plate out after you get done grinding
Chris
in my gallery is a picture of any plate you might need! also make 100% sure while the plate sits in there, you pull up the fuel shut off solenoid and move the throttle linkage forward, and look at where the governor arm will hit the plate... it should hit the bottom of the plate.
JUST NOT RIDE UNDER THE PLATE! If it does ride under, then you dont get the power gain the plate is supposed to give you. To make that right, you'll need to adjust the governor arm, or have a longer j hook on the bottom of the plate
BTW. Are you german? or have german ancestors? Your last name sounds like a teacher's I had in the german school i went to...
92 with 90,000
12-08-2013 11:48 PM
uber_dzl
01-13-2008 11:13 AM
rootremblay
08-30-2007 06:52 PM
