Please help!!!!!!!!
Old 09-05-2012 | 07:48 PM
bigsmokey's Avatar
Please help!!!!!!!!
I just bought a new s300 turbo for my truck from pdr and i am trying to install it. I bolted it onto the manifold but i am having trouble with the oil return line and the tube to the cooler. First i had to take a hammer to the oil return tube to get it to even fit and clear the wastegate an had to turn the housing to get it to bolt on. Now that the oil return line is conected and the houseing is turn to allow it to bolt on the boot to the tube to the cooler is not long enough to reach the turbo. Has anyone had a similar problems and how did you fix it? thanks in advance.
Old 09-05-2012 | 08:26 PM
j-fox's Avatar
Did you call them?
It is a big NO-NO to take a hammer to a turbo!!!
Can you slide the boots enough to get it working on the cold side?
Old 09-05-2012 | 09:37 PM
bigsmokey's Avatar
I didn't hit the turbo I hit the oil return pipe to just dimple it a little to clear the waste gate rod and no I haven't called them yet I am gonna call them tomorrow and I tried I am still like 2 inches short I turned the boots and pipe and tried to steal every little bit to make it reach but I can't get it close enough. I can get the cold side pipe to reach if I turn the housing but if I do that the oil return pipe won't reach. Is there a flexible hose type oil return line I could buy that might work
Old 09-05-2012 | 11:50 PM
Tate's Avatar
You know the compressor cover turns independently of the bearing housing, yes? The later 3rd gens had a flexible drain, but those can be more trouble than they are worth sometimes.
Old 09-06-2012 | 12:45 PM
infidel's Avatar
Just loosen the four bolts on the front of the turbo and the drain can be clocked to any position you want.
Old 09-15-2012 | 03:36 PM
DodgenIt's Avatar
Not any position! Oil Inlet and Drain must be with in 15 degrees of flat for proper drainage. I picked up a flexible oil drain line I believe from source automotive when I had that issue. Worked perfect, Pretty cheap too.
Old 09-17-2012 | 11:36 PM
bigsmokey's Avatar
thanks i bought the flexable tube from source fit perfect. The dodge dealer wanted $107 for a 3rd gen flexable pipe it was only $54 from source.
Old 09-18-2012 | 02:35 PM
DodgenIt's Avatar
Sweet! That's the way to do it!
jamesbfishin
04-16-2016 12:32 PM
DHT
04-02-2010 08:12 AM
SuperiorRam
03-15-2007 04:10 AM
MoparRiggan
01-17-2006 01:43 PM
Lary Ellis (Top)
05-21-2003 11:16 AM
