Please explain these codes??
Ok I read my codes w/ the Smarty today and this is what it threw:
P1693
P0522
P0602
P0500
Now I know what the manual says they are but what does each do and are any of them something to be worried about??
Also I have been having trouble with my throttle being sluggish and sputtering at low speeds and low RPMs could any one of these be causing this??
Thanks
P1693
P0522
P0602
P0500
Thanks
P1693 DTC Detected In ECM Or PCM
P0522 Oil Pressure Voltage Too Low.......Oil pressure sending unit (sensor) voltage input below the minimum acceptable voltage
P0602 ECM Fueling Calibration Error..........ECM Internal Fault Condition Detected
P0500 No Vehicle Speed Sensor Signal.......A vehicle speed signal was not detected
Ok this is what the Smarty manual said as well but does this mean I need a new oil pressure sensor and ECM or PCM and what is the NO VEHICLE SPEED SENSOR SIGNAL mean??
Also could a bad APPS sensor be the cause of this??
Thanks
exwrestler
02-05-2010 10:34 AM
sallyman1
08-26-2008 07:20 PM
Sea01Cummer
28
12-26-2005 09:19 AM
RJMontana
03-22-2003 12:20 AM
