Please describe you DTT tranny shifting
Old 04-07-2003 | 11:50 AM
hellotbone's Avatar
Re:Please describe you DTT tranny shifting
See I want it to shift harder and later. So I should tighten correct? Can I do any damage playing with the TV cable?
Old 04-07-2003 | 02:07 PM
TxDieselKid's Avatar
The line pressure screw can be turned up no more then 3 turns, that's how Bill said to do it when I was on the phone with him a year an a half ago, under the truck. Doing this an the TV cable would be good even on a stock truck. <br><br>Andrew
Old 04-07-2003 | 06:38 PM
AlpineRAM's Avatar
Jamie: Try to set the voltage down to 4.5 or 4.4 V and test then. <br>This will give you higher and harder shifts too. <br>Do not overtighten the TV cable. ( a little bit of endplay must be there at WOT)<br>And note the position before and the voltage . <br><br>HTH<br><br>AlpineRAM
deezeldude
08-01-2006 09:22 AM
ataboy9026
01-31-2006 11:49 AM
jfpointer
01-02-2005 10:20 AM
RedWhiteDiesel
12-01-2003 10:24 PM
MrBilly
01-03-2003 01:10 PM
Quick Reply: Please describe you DTT tranny shifting
