Pics of my twins project
Old 01-22-2007, 10:33 PM
  #31
JDGnut's Avatar
Yea.. that 90 housing is going to spool quick... (most are running something in the 1.20-130 range.) but you can always go to a bigger housing later.. You might have to gate the entire system.. or both turbos to controll the boost.. If you are use the stock gate on the 35 don't forget to modify the exhaust housing by drilling the exhaust so it will controll the boost better.. (Connection both exhaust ports of the exhaust housing.)
They are lots of work.. buy you'll have fun when they are finished..
Bryan
Old 01-22-2007, 10:37 PM
  #32
cyric's Avatar
I already crossdrilled the housing on the 35 and opened up the wastegate to 38mm I also have a 50 mm external gate to regulate total boost.
Thanks,
Joe
Old 01-23-2007, 07:34 AM
  #33
signature600's Avatar
That charger would make a pretty good big single...it's gonna move more air than a "normal" 62mm S300, and spool a bit slower, but it would work! Depending on how much money you have in it, I'm sure some of the turbo shops could put a bigger wheel in it if you need more air. On the exhaust side, just slap in a 50mm external wastegate if it chokes. Fast spool up is your friend...keeps EGT's down, and makes it more fun to drive!
These suggestions are if you want to keep this charger...if you swap it out for a S400/B2 it will move lot's more air, but you'll probably be disappointed in the spool up after driving with the one you have
No problems from my end with explaining things...how else do you learn??
Chris
Edit, just saw you already have a 50mm gate
Old 01-23-2007, 06:52 PM
  #34
cyric's Avatar
Well I don't have any money in this turbo it was a freebie. Soon as the weather permits I am gonna tear the truck down and finish fabbing up the rest of the piping and see how it does. I'll keep you posted. And even if I out grow this setup a good s400 isn't that much and just a few more pieces of tubing to update it. So what the heck.
Thanks,
Joe
Old 01-26-2007, 11:59 AM
  #35
dieseldork's Avatar
Hey Cyric What Size Of Tubing Are You Useing On Your Project?
Old 01-26-2007, 06:29 PM
  #36
cyric's Avatar
I am using 3", 3.5", and 4" exhaust tubing on the cold side. the hot side is a schedule 40 3" 90. I made a new flange and adapter to go from the 2" to 3" at the 35's outlet. I have a print of the 5" exhaust flange awaiting aproval for my gallery. You might just need to modify the outlet to fit 4" it is designed for 5" to fit over top of it.
Joe
Old 01-26-2007, 07:04 PM
  #37
The Guru
Mike Holmen's Avatar
What do you guys think about running a HTT62/14 with a s400 set-up? How much better than running a 40/3b combo? Running my macher's and as low smoke as fast possible on spool-up. I throwing around changing twins combo.
Old 01-26-2007, 07:16 PM
  #38
BigBlue's Avatar
I don't know how much better that combo will cool but I'd imagine that it would spool a ton better. I know my 62/12 from doug lights off stupid fast.
Old 01-26-2007, 09:23 PM
  #39
Registered
blackdiesel's Avatar
man them turbos look good!
Old 01-27-2007, 07:01 AM
  #40
Everyone I've talked to says the 62/12's spool faster than any 40, and move more air too. Just make sure to get one with the wastegates opened up, and the spacer plate so they'll open farther
Chris
Old 01-27-2007, 10:26 AM
  #41
BigBlue's Avatar
I cna vouch for that one.
Old 01-29-2007, 02:56 PM
  #42
dieseldork's Avatar
Hey Cyric Got Another Question .what Are You Using To Weld Up Your Tubing A Mig Or Tig Welder ? And Is Thatschedule 40 3" 90 Is That Like Black Wall Plumbing Pipe And Where Do You Get Something Like That?
Old 01-29-2007, 06:08 PM
  #43
cyric's Avatar
I used a mig welder only because I don't have access to a tig. You could use either. The elbow is a schedule 40 3" elbow. I got it from McMaster Carr the part number is 43425k181. I hope this helps.
Joe
Old 01-29-2007, 09:31 PM
  #44
The Guru
Whats the difference from a 62/14 vs a 62/12 beside the obvious exhaust housing difference? Spool-up vs egt's? I've lived this long with sky high egt's. So would you guys dump the 3B for the S400? Hate to hi-jack. Nathan told me to run a Garret turbo with a wastegate. It moves more air than a S400 and spools the same.
Old 01-29-2007, 11:31 PM
  #45
Swamp_Donkey's Avatar
Mike, You are having sky high egt's with your hx40/htb3 combo?
Quick Reply: Pics of my twins project
