phat shaft 62mm = WOW!
so i burned the stock turbo up got the phatshaft 62 alittle lag at first but when it kicks in hold on to your pants its a great amount of power im still in the break in period but at 20 25psi its as much as my other one was doing at 40.
But one problem when i changed the turbo out i checked on a small leak i had that has became bigger as time goes by well ends up its from my head so would it be a good idea to get head studs and a marine gasket for the engine while i have it off. whats a strong than stock stud that a college kid can afford.
First thing is to retorque the stock bolts!!! Try them at 120. 105 is stock.
If any seem to turn a little extra, that one is stretching. Replace it.
This isn't a fix for a blown gasket but you may save it for a while.
40 lbs boost with a stock charger is a lot of back pressure, or drive pressure.
well ya 40psi is the reason and im feeling the pain i pulled some college fund money out and bought arp headstuds and a new gasket i figure if im going to pull the head im going to do it right. but yes i couldnt resist not punching it when i was getting on the highway broke the wheels loose when i hit 4th and egt not a factor for now i appreciate all the input thanks guys
What exhaust housing did you get, 12 or 14?
If you're not warming your truck up first then that is a fantastic way of joining the blown HG club =P
dodge22
07-08-2009 10:20 AM
Shawn.L.Turbo
07-16-2007 06:21 PM
Smkn600CTD
33
05-28-2007 09:50 AM
4x4dually
01-05-2007 01:07 PM
