phat shaft 62 installed
I'm close to where you are fuel wise. Looks like I need to start saving for that turbo. Keep us posted once you install the TST, as that's the direction I want to go also.
Brad
Brad
Registered
yessir will do. the turbo is awesome. real quick and i can acually hear it. i couldnt hear my old hx35 (and yes, i pulled the ring)
ill be running hot again with the tst. oh well, been runnin like that for a year and a half. she'll be ok till i can get the b2/s400 on there.
![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
when you get that B2/s400 i may be interested in the super ps62 you have now. as a matter of fact I just got off the phone with doug and he said a sps62 would work well in my rig, or even the 64 if i can deal with the lag
Why would you get rid of a B1 and got to a SPS62?? The compressor wheels are the same, but the B1 "should" handle more power ecause of the bigger exhaust side. It is laggier though...probably about as much as the PS64!
Chris
he said he was gonna run a B2/S400 for twins...i got confused.
and the B1 i have is small, it spools great tho, nobody can say its laggy, my old HX55 was laggy
Chris
Originally Posted by signature600
Isn't that the B1 you got from Dusty?? My old one? If it is, it's the biggest B1, next to the Steroid version!
Chris
Chris
can you give me the compressor and turbine size on it? it works great on my truck, looks small to me tho. it spools and cools well.
also blackdiesel...check your PM i sent you info on a new s400 for sale, unless you plan to buy a full kit with one
Should be 62mm compressor, and (IIRC) a .8 W/g housing with the bigger wheel. The exhaust housing may be a bit bigger, there are only a few people who know for sure!
I wouldn't think a SPS62 would do any better or worse...it may spool "a bit" faster, but then you'd sacrifice that"bit" on the top end![Wink](https://www.dieseltruckresource.com/forums/images/smilies/wink.gif)
Chris
Chris
Yeah but you're like 6'8" and I'm (barely) 6'
I'm workin' on that weight part...I started buying relaxed fit clothes, and only carry 6 keys instead of 7. I think I look about 10lbs slimmer already![Big Grin](https://www.dieseltruckresource.com/forums/images/smilies/biggrin.gif)
Chris
Chris
