Performance ????s
Performance ????s
Ok I have an edge-ez rv 275's boost elbow strait pipe k&n but the truck still seems not as fast as it should. I took off the edge and the truck seemed really slow. I guess everything works. 35lbs boost lots of smoke, good fp but i still have trouble leaving stock trucks. I know my gears and the tires hurt but what gives?any thoughts?
Chase
Chase
Tires and gears will hurt (not as bad as my 315's paired with a slushbox),
figure the added weight of of your bumper is hurting you as well,
not to mention it's aerodynamic properties.
EZ and your injectors are made more for towing power, not necessarily speed.
phox
phox
I have mach 2 s and the comp from EDGE. those two alone crank out the power and then a bigger turbo and manifold really set it a part from the others in my town.
ladyram
03-22-2003 12:53 PM
