Which Performance Chip Do you Recommend
Old 02-21-2008 | 07:34 PM
tywebb3's Avatar
How does the Van Aaken compare to the XZT+? At this point I am leaning toward the XZT+ based on what I have read but if the VA is going to do the same thing it would be nice to save the coin.
Old 02-22-2008 | 01:27 AM
MSquare's Avatar
If you start leaning towards a EZ, skip it and get a Comp. You can run it as an EZ, but when you want to jump into some more power (trust me you will), you can tap the wire and open up a whole new area of Yee Haw.
Old 02-22-2008 | 09:03 AM
erics76's Avatar
Originally Posted by tywebb3
What is the deal with the Quadzilla Max Mileage module versus the XZT+? Is the max mileage unit non-adjustable for fuel mileage improvement and no increase in power vs. the XZT+ with the 2 settings?
This max milage module is a XZT+ without the 3rd (timing+fueling) setting. It only has off and timing settings. I believe it's upgradeable on Quadzilla's site, but I'd go with the XZT+ because you're going to want to 3rd setting believe me.
If you go to the big power boxes such as the Edge Comp or Quadzilla Adrenaline, you'll more than likely need transmission work to handle the extra power. Keep that in mind as a new clutch in a manual or adding parts to a automatic will cost more that the actual module.
Old 02-22-2008 | 10:26 AM
nkennedy's Avatar
I have the VA box on my 01, and am very happy with the towing performance; however, it does nothing for my mileage. I usually leave it turned off when not towing.
Old 02-22-2008 | 08:09 PM
DodgeCowboy's Avatar
DTR's Cow Boss
I have a funny question is the box on all the time if the switch is not installed too interrupt it? just wondering cause I have never turned mine off nor do i have the switch but I could not turn mine off I think I would get a over boost code from the elbow
Old 02-22-2008 | 11:30 PM
Jaxn51's Avatar
It's on all the time. I first thought I might want a switch, but haven't missed having it for the last two years.
I'm adding RV275s next, but with a TST PowerMax for a little extra umph. It WILL have an OFF switch.......
Found both in the forum classifieds.
ajpulley
15
02-01-2013 04:23 PM
bansh-eman
29
10-12-2009 12:47 PM
Shooter308
02-24-2007 04:38 PM
RAMROD2006
38
10-05-2006 11:35 AM
imfletcher
15
05-12-2006 09:31 AM
Quick Reply: Which Performance Chip Do you Recommend
