PDR Quickspool cam?
Old 08-07-2008 | 06:01 AM
wurkenman's Avatar
PDR Quickspool cam?
I found a deal on the cam and was wondering if anyone has any input on it? I can get it for 450.
Old 08-08-2008 | 02:52 PM
olddodgetruck's Avatar
i have a pdr cam in my truck. with the twins i didnt notice the turbos lighting any sooner. but a small set of twins like mine start at like 1200 anyways. i did notice it lowered my egts and dropped my boost about 6lbs.
Old 08-08-2008 | 10:58 PM
Mike Holmen's Avatar
The Guru
I liked mine, it helped lots on the drivablity of the truck. Its was just like it states, its will lower egt's, smoke, and helps some on spool-up. Ported heads with the cam is sweet deal if you can do your own and worth the time investment.
Old 08-09-2008 | 07:41 AM
mike i noticed you said you liked it. did you get a diffrent cam. i wonder if it would be worth it going to somthing like a helix h2 from an older pdr cam
Old 08-09-2008 | 09:42 AM
The Guru
I never drove a truck with the helix installed, so my view is just for the PDR. How does your truck sound when idling? Mine kinda sounds like a 12v but with some of the clangy vp. PDR just redid their cam about 2-3 yrs ago, so I don't know which cam you got. I got one of the first second gen re-designed cams. I liked mine, but its three years old. Its way better than stock. Don does good stuff and its on sale so, its a good buy as well. When I overhaul my truck I will try the helix cam, if their still available in a year or so. Inventory is low, and I don't know if Don's still making more. There are a few different vendors out there for cams.
Old 08-09-2008 | 11:57 AM
ratsun's Avatar
wurkenman ~ you wont be disappointed with the QS. Both early and late versions were really well liked.
Unless they changed it since Piers left the new PDR quick spool was the grind that Piers came up with for the third gen he had. It worked really well so they cut the same grind for all three gens and results were great for all. I have never run one but I know a few guys with them and they seem to work awesome. Based on the results of the two cams in Harrys and my trucks it seems the H2 has a little longer legs in the upper rpms than the QS but I think the QS hits a little lower (200rpm)? It would be nice to see some dyno graphs with cam swaps for definitive results because seat of the pants feel is tough to tell.
etn550
04-01-2010 01:12 PM
Txwelder
14
11-11-2007 05:28 PM
Hawkeye
09-23-2003 09:22 PM
nascar mark
11-14-2002 02:29 PM
