part source for HX40/HX35 hybrid
Old 11-08-2004 | 04:30 PM
cj011's Avatar
Hello everyone. I was wondering if you folks could recomend any stores that offered used HX35's parts so that I can make a hybrid with my HX40? Thanks, chris
Old 11-08-2004 | 08:19 PM
RCW's Avatar
RCW
Just about any turbo shop will have a supply of used snails and outlets. The thing to watch with your HX40 is to be sure to have it carefully balanced before you install it on a B series engine as the primary turbocharger. The smaller exhaust turbine needed to avoid excessive throttle lag will cause it to spin up about 20% faster than it's design parameters.
Piers will also likely have the conversion parts you are looking for, he builds a pretty effective HX40 for the baby Cummins.
Old 11-09-2004 | 10:40 AM
OldSmokey's Avatar
Check out High tech turbos. http://www.htturbo.com/
93-12Smoke
08-11-2013 01:32 PM
ddestruel
04-19-2004 04:21 PM
Tartarus
12-08-2003 05:55 PM
Hawkeye
09-23-2003 09:22 PM
atc250r
05-23-2003 08:36 PM
