Part Number for injector Oring?
I was getting my turbo all situated and pulled the dipstick while I was under the hood and my truck is making oil. It has been almost a year since my last injector change but I did not use new orings so now it looks like I get to do it again.
So I need a part number for new orings. The dealer is closed now, but come monday, I'll call them and if they are too much, I'll drive 30 min to cummins.
Anyone have a part number handy?
Alright guys, it looks like you're doing more drinking than typing or researching. I have never bought anything from cummins. People scared me away so far cause I don't even know what a CPL# is. Where it's located on my truck etc.
So if anyone has a part number, I might just go straight to cummins.
you don't even need the CPL# you just need the engine serial #..........and they'll give you any part you need. Engine serial # is on the same tag anyways though. I go to Cummins regularly and I've yet to be asked for the cpl.
I think if a cross over tube was leaking, it would run out of the motor, not into the internals. My cross over tubes have never been out, I only pry them back 1/2" and the oring on them has never been out of the bore.
I'm sure when I pull the valve cover there is going to be an obvious bubbling around the bad oring. What is weird to me is that I watch my oil like a hawk and this problem just showed it's face in the last 3000 miles. I haven't been running anything different as far as additives, just a little two stroke oil from Walmart. I should do all six but that 5th and 6th injector are a pain in the butt to get tightened.
