paper/rubber meterial stuck on oil pickup tube
just got a motor out of my truck, I have never had it apart before, when i got the pan off the oil pickup tube was almost completely cover up with some kind of paper/ruber stuff. i havent seen anything like this before and i dont know where it came from. could it be from an oil filter?
Cummins Guru
Somebody had it a part with all the head work you had done to it. has:lazer cut injectors, head studs, south bend dual disk clutch, 60 lbs valve springs,
was any of it orange? sounds like headgasket pieces, i found a bunch in mine after i blew a headgasket and then later on did some other motor work and cleaned it up. no ill affects thus far
ImpulseHydro
10-05-2007 07:04 PM
