Pacbrake issue
Pacbrake issue
I have the vacuum-operated Pacbrake on the truck in my sig. The solenoid that activates the vacuum valve has failed. Anyone have a source for this part? It doesn't appear on Pac's website......
They also have instructions for disassembling and cleaning it. Do it off the truck, as the parts are small and weird sizes. The screws, for instance, are 2-64 x 1 1/8". Not easy to find. a 2 x .4 x 30 metric will work in a pinch. The O-ring, likewise is hard to find.
Other than that, clean it out with a little WD-40 and put it back together and it should work fine as long as the coil isn't burnt out.
PacBrake also has a special high temp synthetic lube for the brake itself that is a must to have. They can sell it to you direct.
I have also found that if your brake booster is getting bad and dropping vacuum, the PacBrake gets sluggish.
can even try spraying cleaner into the filter check for power and vacuum mine use to act up all the time but good for the last couple of years. call them before you do anything they were very helpful ED
I'd clean it before buying a new one. They are very simple and the only problem usually is they're plugged up with soot.
I have to clean mine at least once a year.
Instructions> http://pacbrake.com/PDF/L5223.PDF
Trick I learned with PacBrake:
If you ask for the parts dept. instead of the order desk and tell him a part broke he sends it for free.
The order desk folks want you to pay.
They've even sent me free new cylinders a couple of times.
PeteWdhd
15
07-17-2013 10:27 PM
Maverick2001
13
06-25-2012 06:28 PM
GreyTD
06-17-2010 10:07 PM
