pacbrake clutch switch install questions
Old 04-22-2010 | 12:19 PM
Jammie Dodger's Avatar
Question pacbrake clutch switch install questions
can i splice wire my pacbrake clutch switch wires to the pacbrake throttle peddle switch wires positive to positive / negative to negative.
if not
what is the easiest way to install my clutch switch?
thanks
Old 04-22-2010 | 01:32 PM
01trailerpuller's Avatar
I would not suggest wiring it into your clutch swich along with the throttle. I would just mount the on/off switch onto your stick. It is easy to turn in on and off from there as you are shifting. Buddy of mine has it that way and after about there 5th or 6th time he down shifted with the switch he had it down pat.
Old 04-22-2010 | 02:01 PM
thanks
already have the switch on my stick shifter. just wanted the switch on the clutch as well ....
Old 04-22-2010 | 08:31 PM
problem solved thanks to pacbrake's awesome tech guy [Bill].
in stall switch and wire into either the positive or negative.
lovin1stgens
08-31-2018 10:49 PM
floravistabob1
31
12-04-2010 04:22 PM
jthorpe
08-20-2008 08:17 PM
budsowner
01-10-2005 12:27 AM
Joel Richards
16
07-06-2003 12:36 PM
Quick Reply: pacbrake clutch switch install questions
