P7100 IP Max HP
P7100 IP Max HP
OK guys I need to know how much fuel I can get this pump to flow? Do not worry about the turbo situation that is taken care of and so is the transmission. So far here are the mods I have in mind
-100plate full forward
-Moddded AFC/ Spring (With pushed all the way back right? or forward?)
-Delivery Valves 191
-Mack Rack Plug (allows for more travel of... I do not fully understand its function)
-Turn the star wheel up too
I think that is it
I also need to know how much the stock injectors are going to be able to flow (put out hp/tq)
Any information is wanted
Thanks guys
Adam
I think that is it
Thanks guys
Adam
wow some how my post dissappeared on my screen so here it goes... i really dont think you can max that pump out ive never seen it happen before because ud need soo much to support it.. injectors a big turbo some way of keeping the egts down
turboman with just a number 8 plate not even moved forward and pensacola diesel injectors, 5inch exhaust and a 4inch down pipe i was all ready pegging over 1500(no matter wat) no adjustments (star wheel) with the stock turbo at 40 psi ... now that i have a big enough turbo to support it i have my 8 plate moved full forward, the star wheel adjusted, and i have an exhaust manifold so its now just close to 1300 from a dead stop and not even 1200 from a roll at 44psi
I agree that you will not likely max it out on a 5.9. P7100 will support huge power with plunger upgrades and what not. I believe there are some tractors making close to 2000HP with a P7100.
Dually Driver
13
11-13-2007 09:10 PM
belfert
09-09-2004 03:23 PM
fishin fever
02-22-2004 08:32 PM
Zino
08-15-2003 10:14 PM
