P-Pump, Worth it?
Old 10-23-2006 | 10:32 PM
  #31
cummnz4x4pwr's Avatar
Originally Posted by 24valvepuller
Sounds like a good time to get your pump set the way you want then
Yeah if it is the pump then its going to Van within the next couple of weeks...we talked in Houston and they are going to be doing a little head work and im taking my new motor i bought to abilene to get the rotating assembly balanced.
shooting for somewhere around 5500 RPM and 900+ cc's of fuel
Jake
Old 10-24-2006 | 12:58 AM
  #32
mvanhelden's Avatar
Now if i were to put the 215 pump in and not mod it, leave it stock, how would it run? would i need to put a plate on it? maybe a Gsk or dvs? or would it run fine with no mods?
Old 10-24-2006 | 10:03 AM
  #33
CarcajouCummins's Avatar
Stock or with a 10 plate would be a great setup. The issues do not start until you try having a dual purpose rig - competition and towing. A 3000 gsk would be a nice addition as well, but 4k is past the limit of the 24 valve springs.
Old 10-25-2006 | 12:03 AM
  #34
mvanhelden's Avatar
My rig would not be a competiton rig, just a daily comuter+ocasional workhorse. And having it p-pumped would be a great conversation rig I have a second vehicle to drive til i got it all tuned right, i'm going to start the conversion in the coming months so i'll keep you guys posted! Thanks for all the info and tips!
Matt
Old 10-25-2006 | 10:51 PM
  #35
cumingetsome98's Avatar
I did the conversion on my 98 24. Started with a 160hp pump and that wasn't enough. Replaced it with a 215 pump with DVs and a GSK and am really impressed. Like everyone else has said fine tuning is the key. I use my truck for fun and pulling a trailer and have had good luck so far.
Old 02-05-2007 | 12:38 AM
  #36
1-5-3-6-2-4's Avatar
draggin up an old post.............
what did you mean buy have to move the ECM? Why is that? I'm bidding on a P7100 now and am just trying to nail loose ends.
Thanks
Old 02-05-2007 | 05:04 PM
  #37
24valvepuller's Avatar
It gets in the way, just hang it anywhere you can, mine is and has been laying on the frame rail. Soon it will be gone along with the pcm and all that wire mess that goes along with them
Old 03-17-2007 | 09:12 PM
  #38
poHmmwv's Avatar
Mpg
I have read that the fuel economy goes down when switching from a electronic to a mechanical pump. But is this because it has been tuned for 500hp+? I am researching the conversion and don't need more than 350hp, 550-600ftlb ( even that is overkill for me). I currently get 25mpg@70mph after an auxiliary overdrive install, other then that my rig is stock. Aside from the engine being in a different make of truck.
Old 03-17-2007 | 10:57 PM
  #39
thekidfan's Avatar
Matt
Dude, you are a lucky son of a gun Brad @ Ponci's is one of THE best techs around....and your right there in Fortuna !! I drive at least 4.5 hours to see Brad it is always well worth the trip
Old 03-18-2007 | 10:23 AM
  #40
My old 94 12 valve that my FIL now ownes gets better fuel mileage than either of my 24 valves ever have, stock or otherwise
Old 03-19-2007 | 01:10 PM
  #41
STACKED's Avatar
too do this swap do you have to change cams and lift pumps, or can u make it work electronic pumps.
Old 03-20-2007 | 02:56 AM
  #42
mvanhelden's Avatar
Here's some crazy thoughts, what other type of injection systems do other engines use? say Caterpillar, Mack, International? would it be possible to adapt and injection system off of one of those engines and make it work on our trucks? i'm sure someones' thought of it, what ever those trucks use must be reliable cause they run for a long time without any probs, well most of them. Oh and i've found out good news since I last posted, the 12 valve's oil pan was just dented, none of the internals were damaged! It was hard to tell at first, I had to cut the engine out with a sawzall and torch! So now i'm just putting the whole engine in, with the wiring out of the other truck, If i can get it out!
Old 03-20-2007 | 10:18 AM
  #43
Ridemywideglide's Avatar
Wanna sell that 24 then?
Old 03-20-2007 | 10:28 AM
  #44
mvanhelden's Avatar
Well maybe, my sisters boyfriend's got a 79' chevy lowered 2wd, he wants it in there real bad, and put some stacks on it!
Old 03-22-2007 | 12:26 PM
  #45
You can use the same cam, but the factory lift pump and all the junk that goes with it needs to be trashed, A FASS or similar style pump works fine you just need to get enough PSI out of it
