is P-PUMP worth it?
is P-PUMP worth it?
with the truck i have in my sig, STILL being a EVERYDAY driver, would it be worth it to do a P PUMP conversion? i am lookin basically for more HP that what i have now and still be able to drive the truck everyday. i really like the idea of making 12v power and with a valet switch, still haveing a everyday driver. just want some feedback on what you guys think.
The Guru
I just put in another VP today. The fourth one for 180000km. The truck wouldn't idle and the power was starting to fall off. This one only lasted 20k. I'm gonna buy a P pump but has to be at a good price. I'm tried of replacing the things but a good running VP truck is hard to hate except for the HP junky's.
From what i've read on this site, when my VP goes, i'm not going to even bother putting another VP in, im going to go straight to a P-Pump...but thats just my two pennies!
with what i have in my sig right now, if i was to do a conversion, how much work i would i have to do to get me back to where i am at right now HP wise and what would i have to do to pass where i am at?
come on guys, i need some feedback . not worried about how much $$$ it would cost, just want to know if i would be able to make more DEPENDABLE hp than what i have now.
But you already know what I think...
Jake
well i understand what you are saying. i do have a P7100 pump just LAYING around and just wanted to know how much work i would have to do to get back to the hp range i am at right now. i am right at 500 to the wheels and i am just lookin for the next step so to say. how hard would it be to get back to 500 with a p pump conversion.
Do you have a 215 P-pump? That would be the first step to make bigger HP then the 160, 180s etc. In my opinion a tweaked 215 pump should get you to 500 HP, of course all your electronic fueling things wont work on the mecanical pump and someone else can chime in as how your budha injectors will work with a P-pump
IMO
yeah i actually have 2 215 pumps here at the house. i mean, yeah i have alont in my truck right now and just wasnt sure if the p pump was the right idea for a everyday driver. i might just have to put some nitrous on the get me to that next step i guess. thats really my goal right now is to have 600 at the wheels. even on drugs. i still need to drive this thing everyday so if i can get to 600 and still have a semi dependable daily driver then thats all i want.
I've been running a p-pump conversion for 3 years now. Reliable, yes. Best, I doubt it. I run in the 450-520 range depending on the setup I am running. A vp will give you adjustability. My truck makes 503hp in full fuel, 130 in valet. But it doesn't have any lift pump/injection difficulties either.
Ron, that sounds like a sweet truck you have there.
I think the swap would be a good option for you since you already have the pump. I think having some bench work done to it, a 4k GSK, a 100 plate and some lazer cuts would get you back to where you are, for less than a VP. And more reliable.
Guys doing a conversion is not that hard...... But getting it to run as well as a VP truck is where the key is. To do this you will need custom injectors, cam, pump, dyno time etc. If dollars is not an issue the conversion is not a big deal (although just swapping a 12v would be a cheaper solution).
Every persons conversion truck I have riden in didn't run as well as a VP truck, although they did run and the owners were happy. For me if I was going to do one I would want it to run as good or better than the VP, and to do this cost time and money.
Doug Smith
Doug Smith
Doug Smith
Doug Smith
Doug keeps hitting on the fine point which is, yes it runs well, but it does not run as well as the vp. You can make power, but you will go back to square one to do it. Delivery valves larger than 181's smoke alot. little RV275 injectors make nearly 500hp with a modest 215pump. Go up to 150hp injectors and only make 20 more hp with 10x the smoke. If I could go to a vp without it costing an arm and a leg I would do it. I have yet to find anyone who actually knew how to set it up though.
Doug Smith
Doug Smith
I have been In a few pulls lately with mine... And I have yet to be beaten by a vp powered truck... you can check out my vids in the comp. section.
Jake
