P Pump Or Monster Vp
ok im lost what is a 913 pump or is that just another name for the pumps on the 12valves or is it a year specific pump like the 160hp 175hp and 215hp pumps do u have a link on a 913 race pump? i have a 98 12valve auto with i think the 175 pump and i was thinking about putting it on my 99 24valve auto since the 98 is a parts truck for me and my brother and a spare parts for my 96 5spd that brings up another kinda off topic ? which pump can be built up for more hp the 160 175 or the 215 my 96 is pretty strong with hardly any mods but i have read from other ppl that a fully built 215 will not compare to a fully built smaller pump sorry if this is to far off topic i have been wondering this for quite some time and this is the place to ask
thank u Tate yeah i popped the hood today on the 98auto and found out for sure what pump it was
if i can find a np205 transfer case and a 4x4 tailhousing for the slush box and find a square nosed stepside chevy 4x4 thats what that motor and trans is going in so a 180 pump with a few little mods should work well once put together i think what profile of fuel plate works best in the 180pump i have a 0 profile in my 215 with it full forward and the star wheel full forward and a little tweaking on the afc housing springs and washers and also full forward and it works well with managable egts and smoke but i guess 5"exhaust and free flowing intake help with that the chevy will just be for crusing around town and on rainy days so its not going to sled pull or anything i dont know much bout the 180 pumps so any help is gratfull
The Guru
I don't get bent out of shape seeing some post some big numbers using NOS. I just want to see some big ponies spinning the roller and to me it don't matter if its on spray or not. I haven't tried NOS yet, but will one day. A stock SO pump will work decently and will make some decent numbers. If you want a big bad pony pump, a 913 with large volume plungers, a custom ground cam, can move tons of fuel. There are shops that have pumps around the 900cc area. I've been told that you can get to around the 700rwhp mark on a near stock 913 pump. Guys running a stick, a p pump can easily be swapped in. 98/99/00 Auto's can be done with not to much adjustments. The newer trucks use the TPS sensor for the tranny computer. You have rig up something to move the TPS sensor as well as pump. You also need the tach sensor to work, so you need a cam plate for the tach sensor for the p pump. The best way to fuel the pump is to put in a aftermarket cam with a lift pump lobe on it as well get one that uses a cam gear bolt. The P pump puts lots of extra strain in the cam gear than a VP. A custom set of injectors for the pump would also help.
Well i would go with a p-pump over a monster! But if you are wanting to stick to a vp there is rumor of a super drangon flow vp from industrial its supposebly flowing twice the amount of fuel as their hot rod on their test bench! Its also going to have a warranty on it even if you tap the pump wire!
The Guru
Ph4tty, How many miles you got on it? How does it work? I hear so many stories on them. I can't feed fuel mine enough right now, and its driving me crazy. I have to buy a new fuel tank, I got a bad tank of fuel and my pick-up is plugged up again. I had a few good pulls, but there still more left.
Industrial Injection is about to offer a new vp also, and suppoce to come with a warranty even if u tap the wire from what i was reading.. so that could be a option
