Oversized tire speed/rpm conversion
Hey guys
So i know if you run bigger tires you go faster and cover more miles than with stock tires but what is the actual formula to calculate how fast you are going based on your tire diameter, rpms and gear ratio
thanks
thanks
If all you did way change the tire size then just go to the tire mfr's web site for both the old tire and the new tire to get the diameter in inches. Then, whatever the percentage difference is between the two will be the percentage that your speedo is off. For example going from a 30" to a 33" would be a 10" difference and when your speedo says 50 you'll be going 55.
John
John
just found what i was looking for on another thread
https://www.dieseltruckresource.com/...ght=gear+ratio
there is a link to a spreadsheet that has the formulas in it
http://www.klenger.net/dodge/general...calculator.xls
thanks for your help
The MOST accurate way to do tire/speed conversions is to use the manufacturer's published number of tire revs per mile.
This can vary even with tires that are nominally the same size. Some 285s for example can be as low as 627 revs/mile, some are up to 635 if they have shallower tread.
Almost every manufacturer published the revs per mile as part of their tire specs. Then you just do some basic math using the figures for your current tires.
Example: my OEM michelins are 655 revs/mile. What if I changed to 315s that were 599 rev/mile?
Math: Old revs/New revs= new speed/old speed.
= 655/599= 1.093
= 1.093= 70mph/X mph
= X mpg= 70mph/1.093
= X mph = 64.04mph
So, going from a 655 rev tire (my 265 michelins) to a 599 rev tire (like a 315 mudder) will give me almost 10% speedometer error, indicating 64.04mph when my actual speed is 70mph.
Hope this is what you're looking for.
Justin
Katmandu
47
06-21-2011 10:46 PM
johnnyboy_10138
09-07-2009 11:05 PM
pooperscooper
13
11-05-2006 08:21 PM
davelinde
07-13-2004 03:15 PM
fishin fever
02-22-2004 09:32 PM
