Overhead Gun Racks
Old 04-02-2007 | 02:31 PM
Buckshotram's Avatar
Overhead Gun Racks
Anybody put one of the Bigsky gunracks cabelas sells in a regular cab with the overhead temp display. What all is involved in the install and do they feel study with 2 7pound rifles up there. Lets see some pics if ya got some.
Old 04-02-2007 | 06:34 PM
Valv's Avatar
7lbs rifles ? I have my AR-15 24" bull barrel that it's 10.5lbs, I sure don't want it over my head when I hut a pothole
Old 04-02-2007 | 07:13 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Not a reg cab but extra cab with the temp sensor mine mounts to the door hinges for the suicide doors. I have two rifles in here at all times and I live on a nasty bumpy road and never have had a worry about it falling down. Buddy has a single big sky bar for his truck that screws righ into the second skin and its just as solid as mine. I would have gone with the screw in one for strength but since this was in the truck when I bought it I love it.
Old 04-02-2007 | 07:16 PM
DTR's Cow Boss
If its the one that bolts direct to the roofs inner skin its just as simple as sheet metal screws and finding a good spot so it will not whack your head. I would make small whole or poke the spots were you will run the sheet metal screws in I had a old dodge ram-charger that I did not do this and the sheet metal screw grabbed the head liner and well you can guess what it did With my sky bar its pretty easy to tell how its mounted
Old 03-06-2011 | 12:38 AM
Damaged 1's Avatar
Anyone know if The roof on a 2005 ,2500 RAM is double wall constructed? I just bought this rack and .... Well now , not sure how to mount it ?
Old 03-11-2011 | 12:42 AM
BorntoHunt's Avatar
I turned my coat hanger hooks around(extended cab) and butted up the skybar rack up against them. You can remove the plastic hooks and double check the depth of your inner liner. I also placed some tennis ***** between the roof and the bar. It definately takes out the vibration from the bumpy roads. I have had this rack for 7 years and never had an issue with a gun falling out. Best gun rack I have had.
H8GAS
18
08-03-2007 07:31 PM
Cowboy45
17
04-19-2006 09:50 AM
Patrick Campbell
10-22-2003 11:00 AM
