overboost code with a box
ok guys i have a van aakens box that has the boost fooler built in and every once in a while if i really hammer it hard it while still pop the over boost code. im getting 26 psi pf boost . could this be just a weak map senser . even thow i changed the map senser out like 10k miles ago. or is my box messing up on me .
the warranty on this truck is long past i have over 122k on the truck . it doesnt mess with the way the truck runs just the light comes on and makes me nervous till i find out its the stinking over boost code again. the map senser was like 50 bucks if i remember right its been awhile since i changed it . i had that happen pre box . talk about making a guy nevous when it happened i didnt have gauges yet and i was sure that i had just taken out the vp44. till i went to auto zone and rented the scan tool .since these 99s you cant do the key trick.
i got it from the local cummins dealer . dont quote me on the 50 bucks but i know it wasnt no 97 dollars . if i remember right i payed like 60 buck after taxes and had them ship it to me since they are like 60 miles from me .
what model van aaken box do you have?mine doesnt have the map sensor plug.only the one to the pump.these single plug models dont have a boost fooler built in,i get the over boost code all the time.with my wastegate disconected.if you have the single plug box you will need a boost fooler.or live with the codes.
it one of the newer ones that does have the boost fooler built in i dont remember what model it is for sure just that its one that has the boost fooler and its about two years old
O.T
09-06-2007 07:10 PM
SSV1761982
01-29-2006 04:32 PM
high country
03-24-2005 11:52 AM
psalm69
09-13-2004 07:34 PM
