Orifice boost elbow on and '01 automatic
Old 10-19-2005 | 06:55 PM
Silverjay's Avatar
I just installed my new Van Aaken box and it came with an orifice boost elbow. I thought I read on here somewhere that you can not run the EZ boost elbow on an automatic. Is this true for the orifice elbow that comes with the Van Aaken? It looks like it delays waste gate operation by creating a pressure drop. Does this change the shift pattern?
Old 10-19-2005 | 08:07 PM
scottsjeeprolet's Avatar
Edge EZ
I put the boost elbow on mine and it doesn't seem to affect the tranny.
i still get lost of smoke at 37 mph and lots of peddle. it gets rid of the tailgaters, and bugs.
Old 10-19-2005 | 08:25 PM
Lrdchaos's Avatar
on the 01 and 02 you can't put the elbow on they changed it where you have to turnbuckle the wastegate.
Old 10-19-2005 | 10:37 PM
TORQUE's Avatar
It depends what type of orifice they sent you. With automatic you have hardline not rubber. You have to drill out and tap, then screw orifice in( if it is same as mine used to be). Maybe they sent you wrong part, call and find out if it won't work with instructions supplied.
Old 10-20-2005 | 08:04 AM
Silverjay's Avatar
The line to the waste gate is a rubber line. I also checked and I have an HX35 turbo. The elbow that they sent has a metal orifice screwed into the brass elbow.
Old 10-20-2005 | 08:51 AM
RowJ's Avatar
01's & 02's automatics could not use the boost elbow...for reasons mentioned above.
It should work with your HX-35, since it has the hose connection to the wastegate.
In 01, Dodge switched to the smaller HY-35 turbo on automatics....strictly for emmisions control. Be glad you have the HX-35! It will allow addition of much more HP before you run out of usable air. Keep your boost at or below 35 psi for max efficiency.
The elbow DOES delay wastegate opening by blocking flow to the wastegate actuator. By itself, it does not change shift patterns....but as you add HP, you will see a minor changes/delays. Not a big concern, IMO.
RJ
Old 10-20-2005 | 11:03 AM
Gotlift01's Avatar
I turnbuckled my wastegate on my 01' Auto and it made a difference. I was barely hitting 20psi before and now I'm at about 35psi...........helped keep my EGT's cooler longer so I could actually stay in the throttle for more than a couple seconds at a time!!
~Nick
JasonblkZ06
06-21-2010 07:31 AM
Itsmejoe231
06-12-2007 06:10 PM
dodgediesel
14
12-14-2006 10:54 AM
G_T
05-11-2005 10:46 AM
