Operation of TST PM3 Comp w/remote
ok, I'm confused...again. I just got my TST PM3 Comp from Wildcat, and the installation instructions look good, but there are no directions on how to use the box.
What does the toggle switch on the box do? The lights on the front of the box and on the remote mean what? How do you know what level you're in (0 through 9)?
Thanks to anybody who can straighten this out for me
pretty straight forward,,switch is to turn it on,,arrow buttons change power levels(1-9),,has a yellow light to let you know you have boost signal,and the green light will come on and get brighter as you push down the go-pedal to show additional fueling taking place........and dont let the pump shudder scare you to much on the higher levels ,,,,and if you dont have a pusher or modified fuel supply,,youre gonna need it.................bama
Thanks bama,
So when you flip the switch to turn it on, it automatically starts out on level 1?
Well I have the higher flow banjo's from Geno's ready to install this weekend if I have the time. I think I'll put the TST in last though once the EGT & boost gauge get here.
Moose
Your possible confusion may be that a number (next to the up/down arrows)shows what level your on. It won't appear till you have power to the box. It IS hard to tell there is an LED window there.
RJ
RJ
dodgediesel
14
12-14-2006 09:54 AM
dodgediesel
24
10-25-2006 04:40 PM
rockjeep73
03-25-2005 03:34 AM
joefarmer
10-10-2003 02:30 PM
