Only 21psi with comp and boost elbow?
Old 09-14-2007, 06:45 PM
kelownadiesel's Avatar
Im also guessing its an intercooler hose.Ive seen 50 psi out of my comp a few times ,mind you it is a drag version so it fuels real hard up top and also ive never seen more than 1250 up there as well on flat ground.You should get close to 40 i would think at around 90 mph. A while ago I took a buddy up a mountain pass to show him what the truck is capable of and we blew an intercooler boot at 40 psi,so Im leaning to that as your problem,but it could be the manifold bolts,turbo clamp etc,whatever.
Old 09-15-2007, 06:41 PM
13ALPHA's Avatar
I tightened all the clamps and bolts, plugs on manifold etc, and noticed the turbo, I see a slight drag mark on the edge of the turbine, looks like it touched, but also, this is what worried me the most....
Is the groove back in there normal, I never remember seeing it, it's about 2-3mm deep, and has a round cross section, kind of rough inside it, doesn't look machined, looks like something ground it in there. After tightening everything still seeing no more than 21 psi. Is my turbo dying?
Old 09-15-2007, 07:01 PM
is there shaft play ,more improtantly side to side or up and down shaft play?
Old 09-15-2007, 09:46 PM
13ALPHA's Avatar
there's some side to side, not a lot, I'll get a better guess tomorrow, maybe .5mm. Can't tell about the forward to back, are both bad? So about that groove, did I just miss it before? It just doesn't look normal
Old 09-16-2007, 12:39 AM
Tate's Avatar
Some radial play is normal. There is clearances for expansion as well as for the oil to flow. As long as it doesn't contact the sides, you'll be fine. Once oil gets into the bearings, it contains the shaft much more than a dry bearing.
Old 09-16-2007, 03:28 AM
Clunk's Avatar
Thumbs up
That machined groove is there to help get air to the inside compressor blades.
Old 09-16-2007, 02:22 PM
13ALPHA's Avatar
Thanks clunk, guess I just need to replace boots next.
Old 09-16-2007, 02:57 PM
Clunk's Avatar
The wastegate may be stuck open, allowing exhaust pressure to bypass the turbine.
Old 09-17-2007, 11:50 AM
13ALPHA's Avatar
I have the adjustable BD elbow, if the screw is alway the way in, shouldn't there be no air going to the wastegate anyway? I don't know if the BD closes completey or not.
Old 09-17-2007, 05:27 PM
Big Blue24's Avatar
wire that wastegate shut and see if you can get more boost. If you have tried a pressured up test and found no leaks, it has to be the wastegate bypassing all of your exhaust drive pressure disallowing the turbine to produce extra shaft power to compress more than 21 psi worth of air.
Old 09-17-2007, 06:11 PM
13ALPHA's Avatar
Just got a cheap plug, gonna try that in a while, if it still leaks, I'll know it's a hose or the IC, even hoses are $.
Old 09-17-2007, 09:39 PM
Big Blue24's Avatar
Even if you plug the line, if the actuator spring is weak or if the wastegate is stuck open, it will still be open, plug or no plug. That is why I said wire the actuator arm shut, the reason why I know is that my buddies truck had a studder/ shudder at 26 psi due to a fluttering wastegate. He had way more fuel than you so even though the wastegate was open he still had enough drive pressure to build 36 psi boost. In this situation, a weak actuator spring allowed the wastegate to open at 26 psi and cause a funny shudder. In your case, with out lots of fuel, an open wastegate plus a handicapped turbo with a jacked up inducer that probably only works half as well as it did new Could equate to 21 psi boost. I don't know, just makin a point that a plug, while partially eliminating the wastegate, does not fully take it out of the equation.
Old 09-17-2007, 09:41 PM
Big Blue24's Avatar
One more point, your sig says something about your silencer ring decorating your tool box. In that turbo pic you posted, I clearly see a silencer ring.
Old 09-17-2007, 11:23 PM
13ALPHA's Avatar
I wasn't thinking and realized what you meant about wiring the wastegate shut. Wasn't trying to say you were wrong. Do you just mean the hx35 sucks in general? Or was mine in bad shape based on the pic?
Only human man... put the ring back in, forgot to change my sig.
Old 09-17-2007, 11:33 PM
13ALPHA's Avatar
Oh yeah, one more point, your sig says something about a "frieght" train, what's that?
dodgediesel
14
12-14-2006 09:54 AM
getblown5.9
10-06-2005 05:42 PM
Barefoot88
08-13-2005 03:28 PM
Eskimo
11-23-2004 09:15 AM
hellotbone
15
04-19-2003 03:44 PM
Quick Reply: Only 21psi with comp and boost elbow?
