Which one first??
Old 11-19-2006 | 12:52 PM
blackdiesel's Avatar
Registered
Which one first??
Do i to the cam and head work first (studs, o rings, gasket, rebuilt head)
OR
do i stick the twins on there and just wastgate them down to 45 psi?
Also, im kinda worried about my water temperature when i start to run the big hp. So when i have the front end pulled apart to replace the cam, what can i do about it/upgrade to?
Old 11-19-2006 | 03:50 PM
Jetpilot's Avatar
Do the cam, headwork, and prep first.
Doug
Old 11-19-2006 | 05:16 PM
TxDiesel007's Avatar
OR
I did the actual twins first
now its not much fun, i cannot push these things to their full potential, Im worried bout my water temp too, Just look up my thead on cooling system upgrades, i now run at 1/2 temp gauge all the time now and well i dont like it,
Rick
Old 11-19-2006 | 07:12 PM
Registered
Doug
thats what i thought. alright. but i hate to drop 2k on the head and not see any acual performance gains, but i know its necessary
Old 11-20-2006 | 12:06 AM
Ph4tty's Avatar
I think you'll notice a difference with the cam even if max hp isn't any higher. Between the wider powerband, lower egts (more usable power), improved spool- the truck will pull harder. Thats why I want a cam. Are you planning on getting the mechanical lift pump too?
Hmm, I'm wondering how many guys upgrade their radiator? Might be worth looking into considering how you use your truck.
usmc2311
11-06-2008 05:18 PM
cameroneod
15
08-05-2007 03:11 PM
CODODGE2500MAN
02-27-2007 04:27 PM
sluggo42
01-19-2007 03:03 PM
12valveford
Off Road / 4x4
04-10-2006 03:57 PM
