Which one....
Old 03-27-2008 | 04:17 PM
CODODGE2500MAN's Avatar
Which one....
Should I go with?
1: VP44, OEM replacement feed pump, fleetguard fuel filter and installation hardware for 1207.52
2:VP44, fass 150 searies high performance lift pump, fleetguard fuel filter and water separator, and instalation hardware for 1631.66
If 2:
SHould I go with the 95gph or the 150gph? They say the 150 is for 500+hp...but you never know.
Is the extra 425 going to be worth if for me running what's in my sig?
P.S. all of the above is through MWFI.
Old 03-27-2008 | 04:36 PM
PaulDaisy's Avatar
I would say, option #2, although I personally would go with a cheaper system than fass. VP44 + aftermarket lift pump of your choice, let your wallet be your judge. Highlands ranch?... na-ah, just do fass
Old 03-27-2008 | 04:54 PM
Tate's Avatar
I'd say go with 2, get the 150 Series 95 GPH unit. Easy to find filters, and you don't need more than 95 GPH unless you are going extreme. 1-3-5-6-2-4 did over 500hp on a stock lift pump, so the little FASS will be good past that.
Old 03-27-2008 | 07:58 PM
2141pete's Avatar
I vote another option, So VP44 and an AD150
Bradleysram
19
05-12-2009 09:36 AM
usmc2311
11-06-2008 05:18 PM
cameroneod
15
08-05-2007 03:11 PM
12valveford
Off Road / 4x4
04-10-2006 03:57 PM
Wade
10-15-2002 06:29 PM
