once more on lights
once more on lights
ok, i did the little jumper for the light mod. to keep the low beam on all the time. WORKS GREAT..... one question, still when i pull the dimmer switch back, just before it clicks to the high beams, it seems the lights get even brighter, especially right in front of the truck like thirty feet, then you click it, the high beams come on, low beams stay on, but this other light goes away. now i know the lights have only two filaments in them, so whats the answer to this one?
the mod you did was for your fog lights. the extra light your seeing is actually your low beams. theres a thread where you can scotch lock 2 ground wire together and make your low stay on with the high to
in fact at the moment its the next thread down
here ya go mechanos
https://www.dieseltruckresource.com/...t=rattlerattle
this is for high and low
for driving lightsget into the panel under the hood behind the drivers battery and pull the fog light relay.make your self a jumper wire to go where numer 3 and 5 (look at the spades on your relay) spade go and keep your relay as a spare
can someone either confirm or disprove whats happening? i cannot believe that a certain spot on the lever supplies more voltage than others. but that must be whats happening.
proudpapa97
05-04-2008 06:50 PM
Nitecap
40
11-24-2006 01:48 PM
CHarlan
08-06-2003 08:40 PM
