Ok, stupid question, where is my pusher pump?
Old 01-30-2008 | 08:24 AM
ScreaminEagle's Avatar
Is it located behind and underneath the fuel filter?
Old 01-30-2008 | 08:27 AM
DodgeCowboy's Avatar
DTR's Cow Boss
Well you don't persay have a "pusher" pump if your truck is stock. The pushers are mounted on the frame rails under the driver seat or some were in the local. The OEM style that you have on your truck is as you described behind and a little underneath the fuel filter on the side of the block
Old 01-30-2008 | 08:56 AM
Ok, thanks. That's what I thought. Is there another pump in the tank?
Old 01-30-2008 | 09:19 AM
Number47's Avatar
not on a stock truck unless the dealer put it in, but it would eliminate the one thats like 8 inches from the fuel filter
Old 01-30-2008 | 10:05 AM
crobtex's Avatar
#1 on this diagram.
Old 01-30-2008 | 11:33 AM
Looks like a real pain to get to. Do you have to remove the fuel filter housing?
Old 01-30-2008 | 01:03 PM
haloman's Avatar
When I changed mine we did. Made it alot more accessible.
Old 01-30-2008 | 01:37 PM
Ph4tty's Avatar
Yes. Its just a couple bolts to pull the FF out. The pump bolts on the pump are a pita to reach. Its much easier to replace once relocated on the frame =P
Old 01-30-2008 | 01:43 PM
I've seen the relocation kit from Vulcan. What is a good pump to go with, Holley, Carter?
Old 01-30-2008 | 02:17 PM
blackdiesel's Avatar
Registered
as far as i remember it was a 5 minute replacement job. It was easy enough to get to with out taking the filter off
Old 01-30-2008 | 06:38 PM
DTR's Cow Boss
When I plumbed my exhaust brake and when I changed the lift pump on my truck all I did was take the top two black bolts out and lay the whole housing off too the side and it was allot better access.
Jim Lane
03-23-2013 10:31 PM
bigredbrick
07-13-2008 05:12 PM
Hoss
05-19-2005 03:28 PM
JKM
03-22-2005 07:29 AM
midwestdually
15
12-17-2004 09:52 PM
