Ok help me figure out whats wrong.
Not according to PDRs chart, Starting at
15* 5.4mm
15.5 5.5mm
16 5.6mm
16.5 5.7mm
17 5.8mm
17.5 5.9mm
18 6.0mm
18.5 6.1mm
19 6.2mm
19.5 6.3mm
20 6.4mm
20.5 6.5mm
21 6.6mm
21.5 6.7mm
22 6.8mm
22.5 6.9mm
23 7.0mm
23.5 7.1mm
24 7.2mm
And right now I am just between 5.9 and 6mm.
15* 5.4mm
15.5 5.5mm
16 5.6mm
16.5 5.7mm
17 5.8mm
17.5 5.9mm
18 6.0mm
18.5 6.1mm
19 6.2mm
19.5 6.3mm
20 6.4mm
20.5 6.5mm
21 6.6mm
21.5 6.7mm
22 6.8mm
22.5 6.9mm
23 7.0mm
23.5 7.1mm
24 7.2mm
Have you looked for boost leaks? You might have have a leak on the IC boots. 55 psi of boost does things that to the air system that you don't get on a stock rig. If your turbos are slow to spool, it could explain things. I would pressurize the system and use soap and water to check for leaks.
Its a 1997 215 pump CPL 2175
fullbore farmer
13
02-14-2008 02:37 AM
ouchman
06-08-2006 11:44 PM
Dan Marino
24
05-15-2006 09:30 PM
shoffs30
10-31-2005 08:17 PM
